Philco "Super" 19
This evening I started making some dog-bone resisters for the "super 19". While working, I had the super tuned to WSM 650. I had a strong signal, it was coming in loud and clear. After a few minutes, the radio developed a crackling/ frying sound. Using an insulated alignment tool, I started poking around. When I touched the bias resistor, the radio stopped playing. When I pushed on terminal on the end opposite the grounded end, I could see a tiny arc where the terminal wraps around the resistor. I replaced the resistor with one from a parts chassis. Now she is playing beautifully again. There are still a few things I need to do. Beside the dog-bone resistors, Need to install the mounting brackets for two of the tube shields. Right now the 75 is the only tube with a shield. I will be installing the "Super 19" in a reproduction cabinet that I finished about a month ago.
If you ever run into a stubborn, uncooperative Philco 19, 71, 89 or 91  that the oscillator refuses to work, Ron's "super"  mod IS the solution! Icon_thumbup Icon_thumbup Icon_thumbup Icon_thumbup
listening to Eddie Stubbs on WSM
[Image: https://c1.staticflickr.com/3/2947/33004...36ec_b.jpg]109_0271 by Steve Davis, on Flickr
i
M R Radios   C M Tubes
I recently did the mod changing the 36 tube to the 77 tube with great success. Originally I had this 19 oscillating pretty well across the band with the original 36 tube. But over time it started dropping out below 1100 kHz or so.
So I made the 77 tube modification, and it works real well now.
That Philco chassis is like an armored tank. I had a heck if a time drilling holes and centering the replacement socket.
I'll be interested in how your adventure with the 6A7 mod works out Steve.
Mark K8KZ
I have had a few projects going so, it has been a while since I have worked on the "Super 19".
I made a few reproduction dogbone resistors and replaced the film resistors that I had installed during the restoration.
[Image: https://c1.staticflickr.com/3/2910/33307...a8c2_b.jpg]109_0282 by Steve Davis, on Flickr
I had made a reproduction cabinet for the "Super 19" last winter before I started the modification .
[Image: https://c1.staticflickr.com/3/2885/34149...a072_b.jpg]109_0292 by Steve Davis, on Flickr
[Image: https://c1.staticflickr.com/3/2835/33306...0874_b.jpg]109_0290 by Steve Davis, on Flickr
Chassis and speaker installed in new cabinet. I used a permanent magnet speaker because I have more chassis than I have original Philco speakers. My thought was since the chassis has been modified and cabinet is a reproduction, I would rather save my original speakers for other projects.
  [Image: https://c1.staticflickr.com/3/2870/34165...977b_b.jpg]109_0312 by Steve Davis, on Flickr
[Image: https://c1.staticflickr.com/3/2850/34165...99ec_b.jpg]109_0305 by Steve Davis, on Flickr
[Image: https://c1.staticflickr.com/3/2852/34165...18bc_b.jpg]109_0308 by Steve Davis, on Flickr
Speechless.
Magnificent job, Steve.
Man I sure do like your cabinet work!
Gregb
Hey...
I recently traded my nice Philco 19B, and then acquired another 19B from Kirk.
So...
This new acquisition will become a Super 19 as well! Icon_thumbup
When I start the work (and it will be awhile), I will start a new thread on it...
Quote:When I start the work (and it will be awhile), I will start a new thread on it...
Ron, I will be waiting.
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
