My 47-1230 Restoration
#31
another interesting thing...
when you get your uglys... find the "INSULATION CHART"
compare that to the information stamped on wiring intended to be exposed to high temps, corrosives, flamable liquids, irregular installations, tightly bundled situations, below freezing, UV breakdown, continuous stress of heating up and cooling down etc...
thats why i mentioned a 10$ junk yard automotive wiring harness with useful color codes exceeds the application of a tube radio.
Best part is 90% of it is flex wiring.
nearly 100% of all the wiring in an automobile will have no information stamped on it,, and if it does,, its because the vendor / supplier just does it.,,not something the auto maker would ask for. The reason is auto makers and others are excempt from NEC compliance yet they are meeting a very stressful application using copper wires.
#32
18 ga. will be fine, actually a bit of overkill. The NEC tables aren't really applicable to our radios. The NEC tables are based on runs measured in feet where voltage drop can be considerable. We are dealing with wire lengths of a few inches at the most, where the voltage drop is negligible.
M R Radios   C M Tubes
#33
I usually go by this table:
http://www.powerstream.com/Wire_Size.htm
This is what it has for AWG18: 16A for Chassis wiring and 2.3A for power transmission. For our purpose we should be using the Chassis wiring and not the Power Transmission.
It is good up to 16Amps which is lots more than anyone needs.
#34
Wow - That's a lot of wire info jcassity!  Thanks!  I actually have the full size version of the NEC book from 1999.  I used it to help me pass the test that allows me to do all my own home wiring.
Rich
#35
Thanks Steve and morzh - I appreciate the input!  Now I just need to find a power transformer ;)
Rich
#36
Yesterday I finally tested the power transformer that was in the 47-1230.  It's the one I put in 45 years ago, so not original.  It didn't take much input...maybe 10vac...before it was drawing 300ma on the primary, so it looks like it's toast.  I still have plenty things that I can work on, but would really like to be able to test it soon, so I need to find a replacement.
Rich
#37
Hey Rich , I'm pretty sure I have one. I will look this weekend and send it to you. Hopefully its good. Warren
#38
(03-20-2017, 11:10 AM)criageek Wrote:  ...yesterday I removed the pushbutton assembly and it's filthy.  What's the best way to clean this up?
I have cleaned several switch and coil assemblies. First I used a small brush and canned air. then I used DeoxIT D5, but used only a very small amount and followed that using foam cleaning (like Q-tips) tips, from the local CVS store to carefully wipe all of the contacts. You already discovered the final step and that is to carefully check all connections for bad solder joints. I have never had any problems using this technique.
#39
(04-07-2017, 12:15 PM)Warren Wrote:  Hey Rich , I'm pretty sure I have one.
That's great!  Thanks Warren  Icon_smile When you know for sure shoot me a PM and we'll work out the details.
Rich
#40
(04-07-2017, 02:44 PM)Tubesforme Wrote:  First I used a small brush and canned air. then I used DeoxIT D5, but used only a very small amount and followed that using foam cleaning (like Q-tips) tips, from the local CVS store to carefully wipe all of the contacts.
Thanks Tubesforme!
Rich
#41
Ok rich, I have the power transformer ready. If you like pm me your address and I will send it to you. Warren
#42
That's great!  Thanks Warren!  PM Sent.
Rich
#43
OK.. the transformer is on its way. I sent it usps priority. You should receive soon.. Good Luck with it. No need to pay me anything for it, just if you can help someone else out here at some time would be nice. Warren
#44
That's very generous Warren...thank you!  I absolutely will help out someone else whenever I can!
Rich
#45
Today's post is about the phono impedance matching transformer.  I doubt that these things go bad very often, so this may not be useful to anyone, but just in case, here is the story behind mine.  Many years ago the RCA connector on mine was damaged and the center pin pulled out.
Obviously this is unusable, so I decided I had nothing to lose by trying to repair it.  So I took my Dremel with a cutting wheel attachment and was going to just try to grind off the heads of the rivets and then pull the top off.  But after cutting a nice groove in the first rivet I decided to try to turn it with a screwdriver, and what do you know...it twisted out!  Here I've taken two completely out and one is part way out.
After removing all the rivets I had to heat up each terminal on the connector and suck the solder out of them.  The center pin of the RCA connector was already gone but if it had been there it would be removed the same way.  Once all the pins were clean I was able to pull the top off.
Here's what the rivets look like.
I'm going to have to splice a little wire onto the wire for the center pin of the RCA connector and glue the pin back into the connector.  But I think I'm going to be able to salvage it  Icon_smile
Rich
Users browsing this thread: 22 Guest(s)
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 4497 online users. [Complete List]
» 2 Member(s) | 4495 Guest(s)
