Threads: 145
City: Elko,MN.
Working on a 38-116 code 125 and have a question concerning bakelite blk. number 46.
This is a 4989SG which is listed on the parts list as having a single .1 uf cap.
If you look on the handy reference guide that I printed out from the Philco site, it does not list a 4989SG.
Anyone know what the proper wiring would be as far as the new .1 cap.
Lugs 1 to 2 or lugs 1 to 3 ?
murf
Threads: 20
City: Decatur Alabama
According to Ray Bintliff's book "Philco condensers and more", the 4989SG block contains one .09 cap connected from lug 1 to 3.
Threads: 145
City: Elko,MN.
Guess the parts list is wrong?
Threads: 145
City: Elko,MN.
After looking farther, I see there is a 4989DG that is not listed as well.
Schematic view and the parts list only show 3 blocks instead of the 6 or 7 blks that are used in the chassis.
What's up ?
Murf
Threads: 20
And according to "Condensers and more" the 4989 DG is two .09 condensers, first is lug 1 to 2, second is lug 1 to 3. Lug 1 goes to chassis ground.
Threads: 72
City: Linn Creek, MO
Quote:Guess the parts list is wrong?
.09 or .1 same thing.
M R Radios C M Tubes
Threads: 20
Oh yeah. Close enough for me.
Threads: 145
City: Elko,MN.
OK, thanks for the info Doc.
I guess the others that are not shown on the schematics will have to be done using the number marked on the block.
Wish it were clearly marked on the schematics so there is no guess work involved.
Thanks again,
Murf
Threads: 145
City: Elko,MN.
(04-10-2017, 08:54 PM)Steve Davis Wrote: .09 or .1 same thing.
Kinda figured that was the case.
Any idea why the rest of the blocks are not shown on the schematics ?
Don't want to guess on these, it is too much work to re-do these.
Thanks Steve,
Murf
Threads: 268
I took a look at the schematic and saw only one #46 cap, screen bypass for the IF amp stage. The parts list sez it's a .1mfd (probably 400v) it doesn't say dual so I'm thinking it's a single unit. Have a look at the eyelet to see if the center terminal has a wire coming up thru it.
As mention .09 hasn't been a standard value for a million years.
Threads: 145
City: Elko,MN.
Hi Terry,
Yes I can see the leads coming thru the rivets, but why don't they show all of the Bakelite blocks on the schematics?
Hate guess work.
Murf
Threads: 26
City: Hayward, California
As im sure you all knew... Doc is right on the two cap blocks info. Just wanted to put my 2 cents worth in.
Threads: 268
Ok....
Does resistor #45 connect between the two ungrounded terminal of 46??
Threads: 145
City: Elko,MN.
(04-10-2017, 10:39 PM)Radioroslyn Wrote: Ok....
Yes there is.
Started recapping the blocks today.
So far so good. 3 down and 3 to go.
Murf
Threads: 268
Ok The other cap in that block is #9 a .05 (a 473 in these new fangled numbers). This is what the schematic shows, parts layout sez different. Having a extra .05mf isn't going to make any difference.
(This post was last modified: 04-11-2017, 07:56 PM by Radioroslyn.)
Paul, thanks,
Anything can help.
Gary
Thanks, lemme look!
PS. Looked it up. They have kits and parts for mod...morzh — 02:45 PM |
Paul, thanks,
Anything can help.
Gary
Thanks, lemme look!morzh — 02:39 PM |
46-1201 Trip Switch Spring
I deleted the other thread, as it was duplicate and did not have the photo.
Please proceed with this one.morzh — 02:37 PM |
Hello, first post here, bear with me.
I've been electronically refurbishing a 46-1201 that I received from a relative. ...ConcernedFeller — 01:46 PM |
I am late to this post, amazing amount of work for a speaker Mike. You must like the challenge. I have a speaker from an...Paul Philco322 — 01:04 PM |
Mike, give this site a look for your spider. Can't hurt.
Take care and BE HEALTHY! -GaryGarySP — 12:41 PM |
Rod,
Bubble packaging? The one I know (if you mean the large bubble type) is really thin. I have some at home.
Is there...morzh — 12:23 PM |
Q8. What's the meaning of life?
I have read that someone made a spider out of the clear plastic from bubble packagin...RodB — 11:07 AM |
So,
Q1. Does anyone know where to get the spider.
Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM |
The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM |
There are currently 3521 online users. [Complete List] » 1 Member(s) | 3520 Guest(s)
