Webster Chicago 56-13 Changer Template
I have a Webster Chicago (Webcor) model 56-13 that came with a cabinet that originally contained an E H Scott Metropolitan 16A. This changer is in the changer compartment, but the drop-in mounting board does not match this changer. I would like to get a mounting template of the mounting board for the Webster Chicago 56-13 so I can cut one that will actually fit this changer. The spring mounting wells do not line up with the springs on this changer and I also believe the projection of parts around the tone arm are going to strike some of the wood on the existing mounting board.
Even a picture of the correct mounting board would help. I could trace out the positions of the spring mount centers on a piece of cardboard and sketch in the general outline of the usual cut-out for the model 56.
Thanks in advance.
This particular changer actually came from a GE radio and has the GE VR cartridge and stylus in it.
Joe
Hmmm,
I cant help but I will ask on my record player group...
Icon_smile
(04-12-2017, 07:07 AM)OldRestorer Wrote:  Hmmm,
Icon_smile
OldRestorer;
Thanks for any information you can find! These older units are difficult to find information about mounting arrangements. It is easy enough to find Rider's data on servicing them, but not anything on mounting of the units.
Joe
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4812 online users. [Complete List]
» 2 Member(s) | 4810 Guest(s)
