Threads: 20
City: Orland Park
State, Province, Country: Illiinois
My brother in law picked this up at a flea market for me a couple years ago. I've never been able to find a thing about it anywhere.
Someone has one listed on ebay up in Canada, but they don't know anything about theirs, either! Mine looks exactly like this one: http://www.ebay.ca/itm/RARE-Antique-True...SwZQRYe927
Anyway, the (poorly applied) ink stamp on the back of the chassis says Truetone Model D9, followed by "C. R. *illegible* No. 236 *illegible*" and "Western Auto Stores".
It's a portable model that from the label inside had one A battery and two B batteries. It's a Five Tube.
Does anyone have a good resource for schematics or info about this? I'd like to tackle it after my Model 20 is done.
Greg
Threads: 69
City: Kansas city, MO.
What tubes are in it? You might compare these schematics against your chassis tube line up.
These are on Nostalgia air under western auto. D937 issue B --D938 issue A---940A & 940B
Not saying they are it, but I ran into a similar problem awhile back with a Western auto radio and found it under a different # than the one on my chassis.
Threads: 54
C.R *illegible* likely stands for C.R.T, Continental Radio and Television, that was Admiral's pre war company name, and they used to manufacture lots of private label radios. If you run into a set that says B.R.C that stands for Belmont Radio Corporation, they too used to manufacture lots of private label radios. You could look on Nostalgia Air under Western Auto Supply, I think that they were listed in Riders under that name.
(This post was last modified: 03-29-2017, 10:54 PM by Arran.)
Threads: 20
City: Orland Park
Tubes are 1A7, 1N5, 1H5, 3Q5 and a 70L7.
Whoever had this in their storage for however many years must have had an awful brown recluse problem. Yikes.
I see evidence of someone having been in here before me... there's a ground lead from the back of the speaker to the chassis that has a mess of solder on it from being done and redone. Lots of paper capacitors and dogbone resistors.
Many thanks for the Nostalgia Air plug, I'll have a look through. I have also seen a couple other models that I believe use the same chassis with different cases, so will investigate that avenue too.
Greg
Threads: 29
City: Wellborn Florida
First four tube would be for a farm (battery) set. 70L7 is a rectifier and power amplifier never seen one before. http://frank.pocnet.net/sheets/093/7/70L7GT.pdf
Threads: 54
If I'm right about the power supply in this set they may be connecting the battery tube filaments, in series with the cathode of the amplifier section of the 70L7 tube, it probably also has a dropping resistor in series with the heater of the 70L7 tube. I have one or two radios that work this way, it gives you much more audio power then the 3Q5 tube would.
Threads: 20
City: Orland Park
(04-01-2017, 02:46 AM)Arran Wrote: If I'm right about the power supply in this set they may be connecting the battery tube filaments, in series with the cathode of the amplifier section of the 70L7 tube, it probably also has a dropping resistor in series with the heater of the 70L7 tube. I have one or two radios that work this way, it gives you much more audio power then the 3Q5 tube would.
Do you think the old A and B batteries are critical for normal operation? The power supply is tiny, which I'd expect for a portable model. Though it does have a switch for battery operation or standard AC. The battery leads are actually in nice shape, so I was planning on desoldering them from their junction and reusing the wire elsewhere.
Greg
(This post was last modified: 04-03-2017, 04:21 PM by WallaceRoger.)
Threads: 268
Well depends. If you plan on operating from batteries yes it will.
For ac operation no it doesn't.
Threads: 54
(04-03-2017, 04:20 PM)WallaceRoger Wrote: Do you think the old A and B batteries are critical for normal operation? The power supply is tiny, which I'd expect for a portable model. Though it does have a switch for battery operation or standard AC. The battery leads are actually in nice shape, so I was planning on desoldering them from their junction and reusing the wire elsewhere.
The "A" and "B" batteries are not necessary for operating the set on AC. Even so why would you need to reuse the wire from the battery leads, that are at most maybe a few feet in length. If they are in good shape I would leave them alone, if you need some cloth wire I would purchase some new stuff from Radiodaze, Sundial Wire, or elsewhere as it would hold up better once you start manipulating it.
This sort of reminds me of what some radio collectors do with farm battery receivers, since they are battery powered they assume that the set is only good as a display item, and they chop the battery cables off. Why they can't just coil up the cable and stuff it in the back of the cabinet I have no idea? It's a real nuisance for someone like me who actually wants to restore and operate a set that has had this done to it, if only because they toss out the battery plugs along with the cable.
(This post was last modified: 04-04-2017, 04:27 AM by Arran.)
Threads: 268
I think what you've got is a truetone 5N chassis. In the battery mode the filaments are powered by the A battery. In the ac mode the mixer, if amp, and det/1st audio are powered by the cathode voltage on the pentode side of the 70L7 thru R-11[Image: http://philcoradio.com/phorum/images/smi..._crazy.gif] A little odd but the rest is pretty standard fair.
http://www.nostalgiaair.org/pagesbymodel...019682.pdf
Hey Mike, must have been a popular chassis as I found it as a BF Goodrich and a Spiegel too.
(This post was last modified: 04-04-2017, 05:58 AM by Radioroslyn.)
Threads: 20
City: Orland Park
(04-04-2017, 05:43 AM)Radioroslyn Wrote: I think what you've got is a truetone 5N chassis. In the battery mode the filaments are powered by the A battery. In the ac mode the mixer, if amp, and det/1st audio are powered by the cathode voltage on the pentode side of the 70L7 thru R-11[Image: http://philcoradio.com/phorum/images/smi..._crazy.gif] A little odd but the rest is pretty standard fair.
This looks exactly right! Thank you!
Greg
Threads: 20
City: Orland Park
I found the 5N under Continental Radio and Television, definitely same unit as mine and the one from Spiegel catalog. Thanks again, guys.
http://www.nostalgiaair.org/pagesbymodel...002989.pdf
Greg
Threads: 20
City: Orland Park
I'm definitely showing my ignorance here, but I started looking at this, and I came to a part that I don't immediately recognize. What is this? It has a bit of thin copper wire wrapped around part of it (which is broken, so I imagine will need replacing).
A lot of the stuff in here is pretty crusty and not much room to work, but I'll get more room as I replace the big old electrolytic capacitors.
[Image: http://i18.photobucket.com/albums/b145/s...110922.jpg]
Greg
Threads: 20
City: Orland Park
Does anyone know what this mystery (to me) part is?
Greg
Threads: 55
City: Lexington, KY
(05-01-2017, 01:37 PM)WallaceRoger Wrote: Does anyone know what this mystery (to me) part is?
Can you see where at least one end of it connects to? See if its location corresponds with R11 (or maybe R12 or 13).
From what I can make out it almost looks homemade. Is it a piece that broke off from the part under the tape with the #4 on it ?
Model 27-84 BUZZ?Humm?
Depends on the type of hum. SOme is made by outside devices.
Try installing an X-cap (0.2-0.5uF) across the AC line, ...morzh — 12:23 PM |
Thank you for your replies.
That is the correct schematic and pin out diagram for the rectifier. The resistance acro...bluecap — 11:01 AM |
Late last night a guy reached out in response to my posting on the Antique Radio Forum and suggested I contact Trust Aut...jrblasde — 11:01 AM |
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
There are currently 3657 online users. [Complete List] » 1 Member(s) | 3656 Guest(s)
