Philco 630 vs Philco 650
I understand the electrical differences.  My question is cabinet size.  Does the 650 have a larger cabinet than the 630?
Thank you
Dave
I corrected the title of this thread so as not to cause confusion - you had "Philco 30 vs Philco 50" which are totally different animals from the 630 & 650.
Anyway...yes, the 650 definitely has larger cabinets plus wider space between the three lower shafts than the 630. You can't put a 630 inside a 650 cabinet, and vice versa.
Thank you Ron
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2994 online users. [Complete List]
» 1 Member(s) | 2993 Guest(s)
