GE H-632U
To get rid of the remaining hum you might try a .01 mfd X2 safety cap across the line connected after the power on switch. It is a good idea to add one even if the schematic doesn't have it. Rod
All, Just for Fun I put in a 25L6G tube . tuned to SW band and motor boating was gone. I could now pickup a few SW stations across the band..
When I put the 25L6GT tube back in motor boating started again..
AM Band not affected..
Go figure?? WHY??? the G version works and the GT does not WHO Knows..
Any Clues??
Skip...
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4798 online users. [Complete List]
» 1 Member(s) | 4797 Guest(s)
