Philco 38-690 electronics restoration.
Threads: 337
City: lawrenceville nj
Aw come on it about 1/2 hr from me could stop in and say hi
Sam
Threads: 11
City: Bellmawr, NJ
YES,,,I understand the reasoning,,,,A Lot of time that could be used elsewhere,,,,I don't blame you,,,, Cheers
Threads: 569
Sam
Lucky you.
If I knew hen you are home I would.
How bout yous two drop by? The pool's open, the beer's cold, the pool table's ready for action.
Threads: 337
Well one out of three not bad
Will bring my beer and no pool thank you. pool table ok
Some day when Im Not working
Sam
Threads: 268
Threads: 569
Sam, you party-pooper you.
He means retirement.
Threads: 569
Rich called, said he has no 14" cones and he's not aware of anyone making them. Suggested a ring and a 12" cone.
I suggested a patch, as he of all people could make it well, he agreed.
The tweeters he said are ok to recone.
Threads: 569
Speakers came from Sound Remedy. Rich did a great job plus he patched my woofer for free, only having charged me $80 for the two tweeters reconing.
Now the transformers. Promised by Heyboer for the mid-July or so.
Threads: 54
Mike;
At least tire valve stems are cheap to replace, of course you have to dismount the tire from the rim to replace it normally.
With regard to the interstage transformer, does this set use a class A-B power amp, with a third triode driving it, a pair of triodes driving it, or is it a class A amp?
Threads: 569
The interstage has to be CLASS A, as it is one pentode 6F6 driving the primary of the transformer which in turn drives the 6L6 pushpull and the tweeters directly.
As for the tire valve, no it ain't cheap, it is the whole assembly for the pressure sensor. Aftermarket is $90 apiece, which is what I did, otherwise OEM in my dealership is $200 apiece.
Threads: 569
I need some break.
Not sure why I am being punished but both transformers came.....incorrect.
I will call them tomorrow, and will or will not publish the results pending their willingness to remedy the situation.
It took 1-1/2 month and.....this.
Sigh.
Threads: 569
I shipped the transformers on 6/13. Today it's been the 3d try to fixing them.
Sigh.
Been 4 months.
Good grief.
The output transformer still has the centertap leaded and one plate lead goes to the fuse. How'm I gonna solder to it?
OK, I'll short the fuse and put an nline fuse to the CT.
I am very sad. It's been three (3) shipping back and forth. I ain't shipping for the 4th time.
Threads: 54
Mike;
Time to go to contact Edcor and see about ordering a new one from them, it won't look the same but the impedances will probably be correct. If they have to build a custom transformer they will apparently refund the engineering charge if they find the specs for your transformer on file.
Threads: 569
Arran,
That's the thing: I do have a transformer I bought for mere $20 or so, a 20W rated 4 ohm to 6,600 ohm PP.
I was hoping to install the original. And....I guess (now that they got the impedance straightened out after 3rd try) I could uee it, but soldering won't be nice.
I think I will suggest tbis xfmr being discounted, as I spent over $40 just for shipping.
Threads: 569
OK. It lives!
Last Sunday I installed the interstage (guess what, the wire colors were correct!) and today I installed the output xfmr. Yes it is ugly as I had to solder external inline fuse.
Then attached the tweeters, the woofer. Thought of powering up tomorrow but decided today. It took it about over a minute if not two to warm up: while some reaction was there when touching the grid caps, a full fleged hum appeared after that much time. And then I pulled the local station loud and clear. No music so cannot judge the tweeters and the quality but the speech is good.
More tomorrow.
Users browsing this thread: 36 Guest(s)
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
There are currently 6004 online users. [Complete List] » 1 Member(s) | 6003 Guest(s)
