RADIO ID please
Saw this at a Antique Store .. They were asking 115.00 I didn't take picture of inside I Should have But it looked nice and Clean.. Had all Tubes present about 5 or 6 I think All Globe tubes .. No Speaker or power supply I think tag said from the 20's No markings on it at all.. I think it was a battery set as it had battery terminals inside ..
[Image: http://i292.photobucket.com/albums/mm38/...6i3n2i.jpg]
Not much to go on..
Skip...
With no markings my guess would be a home-brew three dialer, but it sure looks awfully clean and we'd need to see a picture of the inside.  Probably uses 01A tubes that (if good) are worth at least $10 each, depending on type.
These sets are a ball to play with.  From the mid-twenties you can use ten 9 volt batteries for the B supply and a 6 volt battery or power supply for the A supply.  These sets used headphones or a horn (or cone) speaker.  You can buy a power supply for about $55 from AES:
https://www.tubesandmore.com/products/kit-power-supply
Get a picture of the inside and measure the filaments of the tubes to make sure someone didn't stick in duds for display.  While $115 is high, with good tubes $75 might not be unreasonable if it as clean inside as outside.
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4378 online users. [Complete List]
» 1 Member(s) | 4377 Guest(s)
