Question on 70/90 escutcheon construction
Hi:
I have a question on the Philco Model 70/90 escutcheon: what was it made of? I know there are plastic versions and metal versions.  I know the inside bottom front had the words "Super-Heterodyne."
But I stepped across one that looks like a dead ringer for a factory version, except it is made with stamped metal that appears to be copper washed and instead of the "Super-Heterodyne" in the bottom, it says "Made in USA." Can anyone tell me what I have? Pictures to follow.
Cal.
You have an escutcheon from a Model 4 SW converter, or the lower of the two escutcheons for the 470 or 490 - the one for the SW converter section. This is the only one that says "MADE IN U.S.A." instead of "SUPER HETERODYNE 7" (70 or 35), or "SUPER HETERODYNE 9" (90).
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2834 online users. [Complete List]
» 2 Member(s) | 2832 Guest(s)
