Please ID this Silvertone
Threads: 140
City: Lansdale
State, Province, Country: PA
Please ID Cannot find any info or schematic on this..
[Image:
https://farm5.staticflickr.com/4050/3490...f0b0_b.jpg ]
Thanks
Skip...
(This post was last modified: 09-22-2017, 10:57 PM by
vecher .)
Threads: 310
City: Kings Park NY
Sears Silvertone 1764 in riders 4-3
It is the only one with a 1v tube in the lineup.
See link
http://www.grillecloth.com/sylvania/tube...ubmit&db=3
Riders 4-3
http://www.americanradiohistory.com/Arch...34-STU.pdf
Image(s)
AC: 4 DC: 1
(This post was last modified: 05-23-2017, 12:15 AM by
OldRestorer .)
Threads: 140
City: Lansdale
Thanks Kirk... Was in Joe's shed.. Got it for 10.00
Also got a Heathkit IT-11 Cap tester for 15.00
My heathkit C-3 is not working..
Skip...
Threads: 268
Hope your resistance line cord is good! If not you'll need to scare up a 7.4mf non polarized cap to drop the heater voltage.
Threads: 55
City: Lexington, KY
Nice little depression set Skip!
(05-23-2017, 07:39 AM) Radioroslyn Wrote: Hope your resistance line cord is good! ......
What are the odds of that? We used to find them N.I.B. and you could hear them crack as you tried to straighten them out
Threads: 268
I think I have still have a few of them around some where. Got to preheat them to avoid the crackels.
Threads: 337
City: lawrenceville nj
boy that shed is never ending
sam
Threads: 310
City: Kings Park NY
Geeze,
I better get back there before you clean it out Skip,
AC: 4 DC: 1
Threads: 268
Just what you need some more curtain burners!!!!!![Image:
http://philcoradio.com/phorum/images/smi...on_eek.gif ]
Threads: 140
City: Lansdale
Yup Every time I go in there I find something Different I had not seen before..
Skip...
Threads: 140
City: Lansdale
Where do I find a 7.4uf Cap?
Skip...
Threads: 11
City: Bellmawr, NJ
8uf will work,,,,can,,, I ,,have a hall pass to the Shed,,,,I can help clean it out ,,,lololol,,,
Threads: 140
City: Lansdale
I will check with Joe He is the one doing this for a friend..
I will let everyone know if he has another open house per say.. He is a good friend and its only about 10 minutes from me..
Skip..
Threads: 268
Hey Skip,
Insteadi of finding a 7.4 non polarize cap you could use a 140 ohm resistor @20w or better, and 1N4007.
Threads: 140
City: Lansdale
Terry, I heard that Diodes seem to fail a lot..Maybe that's not true.. Could you draw where in the circuit they should go?
Skip...
Model 27-84 BUZZ?Humm?
Depends on the type of hum. SOme is made by outside devices.
Try installing an X-cap (0.2-0.5uF) across the AC line, ...morzh — 12:23 PM
Thank you for your replies.
That is the correct schematic and pin out diagram for the rectifier. The resistance acro...bluecap — 11:01 AM
Philco 630csx power cord
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM
