Philco 38-5 Restoration Advice
I just had a guy drop off this beautiful 38-5. Probably one of the cleanest chassis I've seen yet (the photo is after a light scrub and wipedown) and it has something I've never seen before...it's original cardboard back.
[Image: http://i.imgur.com/eSdmMeJ.jpg]
[Image: http://i.imgur.com/4cnz8KD.jpg]
[Image: http://i.imgur.com/bT09zNM.jpg]
The cabinet is in great shape except for some topcoat crackle, the typical scuffing at the base and this ONE blemish.
[Image: http://i.imgur.com/2bmiHGa.jpg]
I'd like to preserve the original finish with some topcoats of fresh lacquer, but was looking for some advice on how I can better conceal that blemish. It looks like someone used some sort of epoxy (?) to fill a chipout. I was contemplating some sanding and topcoating, but I don't want to make it any more obvious than it already is. I've been burned "chasing problems" around before where I create a problem while trying to fix another.
Great looking radio!!
If it were mine...I'd probably leave it alone, but then I tend to buy radios that are in bad shape so that no matter what I do they are better off than when I get them Icon_lol
the card board back,,,is the money maker,,,,,
Any suggestions on how I can preserve that back? Are there any sorts of sprays or laminates that can stiffen and protect it? Maybe some clear epoxy spray?
would imagine clear coating it .
but I don`t think it would make it shinny as it would soak in
sam
I see nothing....
(07-23-2017, 09:00 PM)OldRestorer Wrote:  I see nothing....
Might be your browser.....
tgace
all your pic`s are gone
sam
It isn't Kirk's browser, I do not see any of your pictures either.
How about now?
Yes, thank you.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 8845 online users. [Complete List]
» 3 Member(s) | 8842 Guest(s)
