Automatic Radio 8track adapter
looking for any tech info on this.
ON the back it says
"Radio PAK AFM"
I think it is model AFM-9680
I wouldl like to understand what the external friction connections do and if its possible some internal information as well.
I have two of these so if anyone wants one as well let me know, 304 772 3411
wow its been a long time since I seen one of them  umm 40 yrs ago Icon_eek
I believe  not sure  been long time
slide into your 8trac and turn button on push button in front is am/fm
and silver long knob is tuner
should have a magnetic head  like old cassettes did
would not mind having one
sam
an fm only one sold on ebay
http://www.ebay.com/itm/Automatic-Radio-...7675.l2557
this guy may be able to help you
http://www.ccdx.org/ar/ar.htm
down to bottom he has same one
sam
Yeah, i found that link and cant see how to contact him.
i have a clue though,clicking on the webmaster link gets me what appears to be his email.
his site was last updated in 2013,, not sure if i am contacting anyone or not.
clicking send now.
email worked, he replied just now.
He has none of these and he has no info on it.
i am wanting to open it up and see how i get it integrated into input power source, an antenna and a speaker and make it work as a stand alone radio.
Pretty cool piece of history there!  I had my share of 8 track car decks back in the day, but never used one of those.  I'm not sure how it got power or antenna, but if you're wanting to use it as a stand-alone radio you'll need to amplify the output.  It connected to the tape head someway and used the 8 track deck to amplify and control volume, etc.
It would make a better display if you found an old 8 track car deck to plug it into, then all you'd need is 12 volts and a couple of speakers.
I have used cassette adapters to play MP3 players through a factory car cassette system.  They also fed through the tape heads but didn't need power or an antenna and they worked a lot better than I thought they would:
https://www.amazon.com/gp/product/B0716Y...i=13981611
I had one of these,,,it had a rubber bumper that went agains the head of the 8 -track machine,,,How it worked ,,could never figure out,,,good luck---CHEERS
Why re-invent the wheel? What I would do is pick up a stand alone eight track tape deck from a garage sale or second hand shop, one that has a power amp built in, and use it as it was intended. As for how it operates I am not certain, it may steal power from the solenoid circuit, but how it inputs audio into the tape decks amp is another story, I guess it uses the playback head of the eight track deck.
it is power BY,,,believe it or NOT----9 volt battery
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2909 online users. [Complete List]
» 3 Member(s) | 2906 Guest(s)
