3.2 Ohm replacement speaker question
The Hallicrafters SX-122 communications receiver uses a permanent magnet 3.2 Ohm auxilliary speaker such as part R-48A. Will I do any damage to the receiver if I connect a 4 Ohm car speaker until I can find a Hallicrafters or other suitable 3.2 Ohm speaker? Thanks
Elrick, a 4 ohm speaker will work just fine.
M R Radios   C M Tubes
Eico 232 VTVM Schematic
There are currently 3209 online users. [Complete List]
» 2 Member(s) | 3207 Guest(s)
