Threads: 62
City: Toledo
State, Province, Country: OH
OK boys and girls, I'm about 3/4 of the way thru this chassis and I need some help. The dial cord was missing from this when I got it and looking at it I have no idea how its suppose to go. Who has a diagram of the layout?
Threads: 567
Threads: 62
City: Toledo
That does help, thank you. Now I'm just waiting for my top rubber cushions for the tuning capacitor and I should be good to go.
Threads: 62
City: Toledo
Heres another question, anyone know what the collapsed length of the spring is? I have a box full of springs here but I'd like to avoid the experimentation portion of restringing this.
Threads: 62
City: Toledo
Well, the springs I have don't have the strength needed. I found a supplier on ebay and ordered some. Hope they will work.
Threads: 62
City: Toledo
I picked up some springs off of ebay that are stronger than the ones I originally had but I'm still not able to get the tuning cap to move. Doesn't matter how tight I tension the dial cord the tuning shaft just spins when turning it without moving the cap. Maybe I'm using too thin of cord? Any one else run across this before?
Threads: 268
Maybe a little bow rosin (instrument) might be a good thing.
The cord needs to be thick. Very thick. I don't have my micrometer handy but the cord used in Models 15, 19, 89, 77, 96, 111, 112, etc. is very thick, at least double the diameter of a paper clip.
Actually, I think all of the pre-1939 Philcos that use dial cord use the very thick cord. This also includes models 71, 91, 14, 18, 118, etc.
Threads: 54
It probably also needs another turn or two of cord wrapped around the tuning control shaft.
Threads: 62
City: Toledo
Thanks for the replies. Not sure what to use then or where to purchase same. Arran, there is no room on the pulley for a second wrap, it would just get twisted on itself.
Threads: 337
City: lawrenceville nj
how about joann fabrics
they have different types of yarn and knitting stuff
sam
Threads: 62
City: Toledo
I just ordered some .062 diameter dial cord from Adams Manufacturing. I'm hoping that this will work since its twice the thickness.
Threads: 62
City: Toledo
I got the thicker cord and tried it out. It is very hard to turn the cap from the fully closed position with alot of slipping but much easier to turn it towards the fully closed position. I think this is being caused by a lack of proper lube on the bearings. I was using some Philips grease that was designed for gears and bearings but I think its just abit too thick.
Tomorrow I am going to pick up some Tri Flo and some Monkey Lube and see how those work.
(This post was last modified: 08-18-2017, 05:25 PM by Jim Dutridge.)
Threads: 62
City: Toledo
Take my advise, go spend $6 for a 2 oz. bottle of Tri-Flow. This stuff works great for tuning cap bearings and just about anything else that requires lubrication, short of phonographs that is.
If your dial cord still slips, melt some violin rosin in acetone and then spread the mixture over your dial cord. The acetone will evaporate quickly, leaving the rosin deposits which will help your dial cord to grip better. I suggest you do this outdoors with plenty of ventilation as acetone fumes are not exactly good for your health.
Bill Turner used to sell this mixture and it works great.
Yes, standard alignment procedure. I can get the minuscule tone to vary when adjusting the trimmers. But you almost have...Radios1340 — 01:40 PM |
An imposing-looking radio, for sure.morzh — 12:43 PM |
Model 60 struck again :lol:
Welcome to the Phorum!
Above is the article on Model 60. Could be of some use.
Now...morzh — 12:38 PM |
Ooh, very nice!jrblasde — 12:19 PM |
I am picking up this radio today. The seller tells me it is all there and working.including the tuning eye.
It has 13 tu...Dan Walker — 12:07 PM |
Hi guys! I’m a new member here but have been using your resources for quite some time. Hopefully I can get some help wit...Radios1340 — 11:52 AM |
Milkjug plastic?morzh — 09:36 PM |
Yep.
'Cause when I heard "buibble" I immediately thought of this
and started wondering how this poly...morzh — 09:33 PM |
Blister Pack, that's what I was trying to remember!RodB — 09:29 PM |
In the packaging biz we refer to the package as a clamshell or blister pack if on a cardboard. So we are using the packa...Paul Philco322 — 08:13 PM |
There are currently 4754 online users. [Complete List] » 3 Member(s) | 4751 Guest(s)
