Philco 20A - Electronic Restoration Questions
What do you typically do with that whole tar package in the big tin can?
Throw it away? Keep it? Keep it still in the can?
- Eric
Philco 20A
Zenith T825
I toss them. No use.
Gut the can,,,use can for NEW Capacitors,,,CHEERS
Into the garbage.
Greg
I'm very new to the different types of capacitors and where I live, I cannot go to a local store to pick some up, they've got to be ordered online.
Where are you guys finding these high voltage rated caps? The 2 uF film caps with over 400V rating that I'm finding are in the $7 - $10 ranger on Mouser. DigiKey doesn't even have them available...
- Eric
Philco 20A
Zenith T825
http://www.tuberadios.com/capacitors/
Use two 1.mfd in parallel, there 75 c ea.
Ah! I had completely forgotten about the parallel & series rules for capacitors. Thanks so much! And for the link too Icon_smile
- Eric
Philco 20A
Zenith T825
Since your radio is a 20A rather than a 20, the values of your original filter capacitors are a little different. The 20A was designed to work on 25 to 40 cycle AC so the filter capacitors were a little higher value. My recommendation would be to use a 1.0 uf for the first filter (terminals 1 and 2), a 4.7 uf for the second filter (terminals 1 and 4) and omit the capacitor that parallels the choke (terminals 2 and 6).
M R Radios   C M Tubes
I bought some large assortments of 630v film capacitors and resistor assortments on ebay, they usually have free shipping, too. If you go that route, be sure you check where they're shipping from, a lot of them will be from Hong Kong and if so, you'll be waiting a couple weeks for them. There are several there that ship from within the US though.
The original resistors in the 20 are 1 watt, I only had 1/2 watt so I doubled up on resistance and ran them parallel to get back to 1 watt at correct resistance spec.
Greg
Sal's is good. While we're sharing links - a few more sources for parts (in general) you should know about:
http://www.radiodaze.com/
http://www.justradios.com
http://www.renovatedradios.com - reproduction parts (especially rubber parts)
For restuffing bakelite blocks I used the film caps from here:
http://www.capacitorworld.net/product/me...apacitors/
For replacement electrolytics I like to buy a good quality brand like Nichicon - usually from Mouser.
Are the electrolytic caps the two business card sized units which go to ground? #13 & #14 on the diagrams?
- Eric
Philco 20A
Zenith T825
The Philco 20 has no electrolytic capacitors.
(08-10-2017, 11:05 AM)Steve Davis Wrote:  My recommendation would be to use a 1.0 uf for the first filter (terminals 1 and 2), a 4.7 uf for the second filter (terminals 1 and 4) and omit the capacitor that parallels the choke (terminals 2 and 6).
Got it. Would you mind explaining a little why deviate from the spec sheet recommendation on the 20A condenser values? I'd like to understand the change.
Does it smooth the DC out better?
- Eric
Philco 20A
Zenith T825
The 20 was a US built set the 20A is Canadian. In CA the AC line power was 25cy not 60cy like we have here in the states. Being the the power is a different frequency it calls for a larger power transformer and a different sized filter cap to filter out the 25cy hum. That's the short answer.
When this radio was made, large value capacitors were physically large and expensive. Radio manufactures tried to use the lowest value capacitors they could get by with. One of the tricks Philco used was to use a specific value capacitor in parallel with a choke to create a tuned circuit to filter the hum. The problem with that is, if the value of the capacitor is either too high or too low, it can actually increase the hum. Some may disagree, but I think it best to omit this capacitor and increase the value of the second filter to compensate. It is not a good idea to increase of the first filter because this will increase the B+ voltage.
Ooh, very nice!jrblasde — 12:19 PM
I am picking up this radio today. The seller tells me it is all there and working.including the tuning eye. It has 13 tu...Dan Walker — 12:07 PM
Hi guys! I’m a new member here but have been using your resources for quite some time. Hopefully I can get some help wit...Radios1340 — 11:52 AM
There are currently 9423 online users. [Complete List]
» 2 Member(s) | 9421 Guest(s)
