Green eye tube won't turn green!
Threads: 242
City: West Bend, Wisconsin
Here's a new one I never encountered before. Working on the Zenith model 8S463 I picked up last weekend. It's been recapped / (most) new resistors, all carefully installed. Checked and double checked. The radio plays, albeit a bit garbled. However when I plug in known good, bright green 6U5 / 6G5 eye tubes, they don't light up green at all! I can see the filament lit bright orange, and the voltages are there on the eye tube socket plug, but no green. It's like a dead eye tube. I take it out, test it in the tube tester, and it shows bright green. Any ideas what would cause this? I have a new 1 meg resistor across pins two and 4.
Here's a link to the schematic:
http://www.nostalgiaair.org/pagesbymodel...025455.pdf
Threads: 55
City: Lexington, KY
I'd double check all the voltages while the tube is plugged in. If you don't have a tube manual the 6U5 is p. 141 in the following manual:
http://www.tubebooks.org/tubedata/RC15.pdf
It sounds like your plate voltage might be missing or low. That 1 meg resistor (if open) will keep the eye from closing.
Threads: 268
Have a look at R-18 to be sure all of it's sections are ok. The 52 ohm section is the ground return for the I tube among other things.
(This post was last modified: 08-25-2017, 08:50 AM by Radioroslyn.)
Threads: 563
On Zeniths the 1M resistor that is usually located inside the socket often is open.
One way of replacing it without opening the socket (which is backelite and appears to already have cracks so opening it almost guarantees it won't survive it) is the way I did it for my Zenith 9S262.
You could find the topic, from, I think, year 2012.
In essence, I took a surface mount 0603 resistor, which is small and flat, soldered two thin strands of wire to each end, threaded them in the appropriate pins, laying resistor flat on the surface and re-insert the tube. The power dissipation is negligible so this works just fine.
Found it, here it is.
http://philcoradio.com/phorum/showthread...th+9-s-262
The photos are on the last page of the thread.
Threads: 242
All is well...once I got my head on straight I realized I counted the pins counter clockwise instead of clockwise. It's shining green once again
Threads: 563
Yeah that stuff will get you dizzy
Threads: 18
City: Mesa, AZ
I restored an 8s463 about 8 years ago. Very nice sounding radio! Glad you got the eyeball working, as I had to replace the meg ohm in the socket on mine. Tedious, but do-able!
Threads: 1
City: Indianapolis Indiana
Most definetly check the resistor at the tube socked base. takes a little work to get to it but take he cover off of the socket to the tube , read the resistance with tube removed from socket.
Threads: 563
Oldswab,
He said the tube is working now
Threads: 242
+1
Late last night a guy reached out in response to my posting on the Antique Radio Forum and suggested I contact Trust Aut...jrblasde — 11:01 AM |
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
Model 27-84 BUZZ?Humm?
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM |
Is the tube in your radio actually 35Z3 or 35Y4, or something else?morzh — 10:55 PM |
There are currently 2646 online users. [Complete List] » 2 Member(s) | 2644 Guest(s)
