Micamold Capacitor Value and Type ???
Can one of the knowledgeable members help me identify the type and value of a Micamold cap? Illustration of the cap follows. This item is from a Philco 41-290, first IF can (item 32 – p/n 32-3482). Cap is about 3/4" x 3/4" in size.
Note from site admin: Sorry, but the photos which were attached to this post are no longer available.
Ok I'll take a stab at it. The top red dot = 2 (20%) Bottom dots = 300. 300pf@ 20%. If it's on the plate side of the coil go with a 500v job ( common).
Good Luck
Thanks for your reply. If the bottom dots are the cap value, I think it should be 30 X 100 = 3000pf.
First digit (orange) =3, second digit (black) = 0, and multiplier (red) = 2 or 100. At 3000 pf, it is unclear to me if this is a encapsulated paper cap or a mica.
Any thoughts will be appreciated as the schematic does not detail the value or type for this cap.
Thanks
According to this website, TFB, you are correct.
But I wonder about 3000 pF in that circuit?
Very interesting. The primary of that IF transformer is slug tuned, as are many 1940-42 Philco IFs, and it uses that mica cap in parallel with the primary winding.
Being a Micamold cap, it's hard to say if it really is mica or not. Some Micamold caps have a paper cap encapsulated in that package that looks like a mica cap. The Micamolds are beginning to fail at a rising rate, also.
I would replace it with a new mica cap or an NP0 ceramic to avoid drift while in operation.
Don't know but .003 seems a bit large.
I just happened to look at a schematic for a 41-295 (fairly similar unit) and it details this cap at 3000pf. I also thought this was somewhat large and was the reason I posted the inquiry. At 3000pf (.003mf), it's likely to be paper and I'll replace it while I have the IF can disassembled.
Thanks to all for you assistance.
Good catch, TFB. Thank you for enlightening us.
New member
Philco 630csx power cord
New member
There are currently 4043 online users. [Complete List]
» 2 Member(s) | 4041 Guest(s)
