portable speaker ???
ok guru`s
here`s a portable speaker in leather case  (not in gallery)
only ID is   stamped on speaker  and a stamp in case
I take it stamp on speaker is just part numbers
connector looks like some one put on to use with a transistor radio
This being a PM speaker of a modern type, likely 8 ohm, or maybe 4 ohm, it can work with any transistor output of proper power.
Never knew one existed. Thanks!
Icon_lol
I almost bought that..
Icon_smile
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
