Heathkit IT 12 signal tracer
Hey, guys. Anybody have a suggestion as to what would be a good replacement for the output transformer in this thing? Thanks, Ed
Hi Ed,
It's about 7K to VC. I have some small multi match opts that should fit and work. PM me w/your info and I'll drop one in a sack for you.
Terry, pm sent.
Got it.
