Philco 116B
Anyone know if the Philco 116B tombstone chassis originally had a metal plate on the bottom?
My late model one doesn't.
I have never seen a metal bottom to one of these chassis. None of mine have one.
The speaker table error?
Philco 70 antenna lead
