Still '' ANOTHER'' Deforest Crosley
They warned me ,, when I started in this radio collecting hobby, that I would get hooked,
but I didn't listen to them.
  Well this  is the third Deforest Crosley this month.
 It is a model 8D991, and supposedly  rare.
 I tested the 6X6 eye tube and it glows OK, not bright , but livable.
  Of course the cabinet has to be done. The radio has a beam of light dial which I am looking
forward to seeing in action.
 Here are some photos
 Dan in Calgary
   Living in Calgary Alberta
Wow, That veneer is super nice..
I love that dial too... Its so.... BIG! Icon_lol
Icon_smile
Once properly refinished, it will be a real looker.
WOW and double WOW I am with Kirk I love it!
Dan;
  Your set is called the "Liszt", I have that set's twin brother called the "Brahms" model, the difference is that the "Brahms" has motorized tuning which they charged an extra $10 for, other then that it's the same as the "Liszt". Your cabinet is a little better then mine, mine needs some chipped veneer repaired on the top, and mine is missing two of the knobs, the outside ones I think. In terms of rarity I'm not so sure, I've seen at least three Deforest-Crosley "Liszt" models for sale on craigslist sites in my region over the past two years, the last one being in the Victoria area. Unfortunately some busy body decided that the four original controls were not enough and added two extras, right through the front panel, next to the band switch. I can't recall seeing another "Brahms" model but I must have seen at least one for sale, I have seen at least two of the "Rogers" equivalents of the 10 and 11 tube chassis models. It stands to reason that the non motor drive version would be more common since it was less expensive, $10 was enough to buy a five tube AC/DC in the pre war years.
I just finished recapping this one and I find that the 6X6 tube is quite good,which is unusual.
 It plays very good, and the dial is nice.  Here are a couple of photos of the tube.
  Dan in Calgary.
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2829 online users. [Complete List]
» 3 Member(s) | 2826 Guest(s)
