Am looking at some pix of a 39-70 and was wondering if it has the dreaded rubber wire? The battery cable does and it's a mess.
Yes, it does...
New member
Philco 630csx power cord
New member
There are currently 4026 online users. [Complete List]
» 2 Member(s) | 4024 Guest(s)
