GE Model 200
Working on a GE Model 200.. Question
How do you get the glass out without breaking??
See pictures..
[Image: https://farm5.staticflickr.com/4447/3674...2236_b.jpg]
[Image: https://farm5.staticflickr.com/4484/3741...fa6c_b.jpg]
Thanks
Skip...
I believe,, they are clips-- that flip open---out-----BUT could be __WRONG,,,,and they JUST ,,lift a little to get glass out??????//// they also look like fansworth clips,,,with a little wedge in them ,,to hold that main part tight,,and down ,or against the glass,,,,,Can't really tell from this point of vision,,,----hope that may HELP-----CHEERS
Yes.. Was able to get glass out . One clip broke on right side and was able to slide glass from other two..
Thanks All
Skip...
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 2960 online users. [Complete List]
» 3 Member(s) | 2957 Guest(s)
