Philco 54 or 57?
Hello
I found a 4 tube Philco according the wooden cabinet it looks like the model 54, but according to the wiring diagram it looks like the model 57 but the tube layout is different
I have:
1 x 80 rectifier
1 x 41 output
1 x 6C6
1 x unknown
The 57 circuit schematic shows 2 x 77´s, 1 x 42 and 1 x 80
I do not find any information on the voltages on the tube pins
Your help will be appreciated
Best Regards
f
Hi
Model 54 is an AC/DC set and uses five tubes. Models 57, 58 & 59 use four tubes: (2) 77, (1) 42, (1) 80.
6C6 is a substitute for the 77, but the radio will probably work better with a 77 installed.
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4013 online users. [Complete List]
» 1 Member(s) | 4012 Guest(s)
