Chassis vernier removal question
Hope this is the right section for this.
According to Philco's Service Bulletin #273, they refer to a lock pin that holds the pinion gear and shaft in. The instructions state to place a wood block on the side with the pin and to rap the block sharply to get the pin out.
Well, that confuses me.
Am I to assume that the pin is supposed to back out on it's own?
I'm not sure because it appears to be pressed in.
Any help would be greatly appreciated.
just to clarify...is this question for the 37-675 radio?
Hi Klondike
I could not get that pin out, I tried to get it out using the block of wood it did not work for me. I admit I did not "tap" it to hard. I just cleaned it really good and just live with it. Mine was not too loose. I have a 37-675. Mine had a lot of open coils in the RF part. Also the dial that I bought is not correct for a 37-675 the low end of the new dial is no right.
Joe
Sorry, yes for the 37-675.
I figured out that I did not need to remove it. I tried a little sewing machine oil and it loosened the vernier shaft up really nicely.
Which dial did you order?
There are 2 different dials available and the Philco part number for the 37-675 with the autotune uses the 25-5207 number. How does it look because I need to order one myself.
(I can't not get the quotes to work properly, must be something quirky with chrome browser?)
I don't know if the pin has a taper to it or no, is it does then it will obviously only come out one way, so if tapping on it one way doesn't remove it maybe tapping it the other way will?
If your vernier drive system is like my 37-116, try using a magnet. I used one of those telescoping magnets for reaching tight spaces and the pin came out with no problem. After that, you can pull the assembly out but be careful that the 3 ball bearings don't drop out and get lost on you!
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
(11-10-2017, 08:46 AM)462ron Wrote:  If your vernier drive system is like my 37-116, try using a magnet. I used one of those telescoping magnets for reaching tight spaces and the pin came out with no problem. After that, you can pull the assembly out but be careful that the 3 ball bearings don't drop out and get lost on you!
Ron
I did try one of those neo magnets from a hard drive and no movement. As stated, some sewing machine oil loosened the drive up nicely. Not the preferred method, but I was not interested in beating on the shaft housing unnecessarily.
Ooh, very nice!jrblasde — 12:19 PM
I am picking up this radio today. The seller tells me it is all there and working.including the tuning eye. It has 13 tu...Dan Walker — 12:07 PM
Hi guys! I’m a new member here but have been using your resources for quite some time. Hopefully I can get some help wit...Radios1340 — 11:52 AM
There are currently 8539 online users. [Complete List]
» 2 Member(s) | 8537 Guest(s)
