Question about a Philco model 44 code 121
Hi everyone,
    Picked up a nice Philco model 44 cathedral from an estate sale
    over the weekend. While looking it over for the first time I noticed
    the wave band switch worked very well on a up and down gear
    system, but the station selector was free wheeling. My question
    is does the station selector also work on a gear system and if so
    how are the gears set up? I did notice that the selector shaft
    had a small gear on it.
    Also the dial scale is good but dirty. How is the best way to try an
    clean it?
    Thanks for any help and information.
    Tom72
Hi,
Everything you need to know about the model 44 dial drive may be found here:
http://www.philcoradio.com/phorum/showth...?tid=14970
Don't use water to clean the dial it will take the ink off of the dial I think there is a post that you should use mineral spirits but don't rub to hard.
Vinzer
Hello Vinzer , Good morning from France Everybody
Indeed , everybody has , on time , encountered the problem of disparition of the inscriptions on a dial , when trying to clean it .
Please which kind of " mineral siprit " do you recommend to use ???
best regards
Ron and Vinzer,
Thanks so much for the information.
Just what I needed.
Tom72
I use whatever is cheapest.
Claude,
I'm not sure what product this would be in France but a typical mineral spirit product we would buy in the local hardware store would be something like this one:
http://www.rockler.com/klean-strip-odorl...4XEALw_wcB
I like to use the low odor type just to keep from stinking up the house.
The Material Safety Data Sheet for this can be found here:
http://go.rockler.com/msds/klean-strip-m...ts-sds.pdf
Claude
It is Naphta Lourd in your case (also White Spirit).
thanks mike! I thought you might have an international translation for that product... Icon_thumbup
Hello Friends
Thanks a lot for détails  !
Indeed , White Spirit is a well known product , used for dilution of most of paints or cleaning art brushes  !
I wish you nice week end  Icon_smile
Same way it is known in my language, "уайт-спирит", a transliteration of pronunciation of "white spirit" (oo-eye-t spee-reet). Though we stress the last syllable.
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 3639 online users. [Complete List]
» 3 Member(s) | 3636 Guest(s)
