48-200 code121 Filament Wiring incorrect
#31
Houston, we have a problem!  There is no pin#6 on the 35Z.  See Tube diagram Pin#5 is the plate.  What do I do?  And I said I knew everything!
Correct amoundo!
Let's take a journey back in time abt 4hrs ago.
>>This is fine if there is something else connect to pin 6 also as it has no internal connect to the tube. A common configuration would be to have the 220 ohm resistor between pins 8 and 6. 6 being used as a tie point also it would have the 1200 ohm resistor connected there.<<
So are you saying that there is no terminal on the tube socket for pin 6??? I realize that there isn't a pin on the tube base.
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 4538 online users. [Complete List]
» 2 Member(s) | 4536 Guest(s)
