A Jackson Bell model ????
As Russ said, this radio was built after the real Jackson Bell went out of business in 1932.
A couple other companies squatted on the name. I have a '36 radio with the Jackson Bell tag. But it was made by Mission Bell for a company named Pacific Radio.
https://www.radiomuseum.org/r/pacific_r2_506.html
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
