New owner of 16b shouldered Tbone
Threads: 147
City: Dallas, TX
Threads: 54
Fred;
It looks like the front panel is still original, but that someone stripped and clear coated the top and sides. This isn't too surprising since the original shading lacquer has a habit of flaking off, I believe that the top, sides, front moldings, and the base were originally extra dark walnut, or something similar, if the 1936 model 116B is anything to go by. There is a picture of a 1935 model 16B, Ron's set, that is in the banner above this page actually.
Threads: 147
City: Dallas, TX
Thank,s Arran, I was thinking that the sides were supposed to be extra dark walnut along with the base molding. In the header banner for Rons radio looks good but dosen,t look like extra dark walnut, looks black but could be the lighting in picture. The raw looking wood on mine wont cut it, the front control panel seems to be correct with out hardly any clear on it yes it had been stripped at some point and not finished. The wood veneer on this set is tight and perfect. Will look fantastic wen refinished properly. Chassis will go thru my normal cleaning and service to get it up and playing safely.
Correct - it was the (poor) lighting in the picture; the trim and sides are Extra Dark Walnut.
Another example is here, although the trim on this one is too light. It should be Extra Dark Walnut, but applied light enough that the grain still shows yet dark enough to make it very dark brown.
Now this 118B is not the same cabinet obviously, but has the same toning. You can tell the finish on this 118B is original as it is flaking. You can clearly see the contrast between the dark trim and the Medium Walnut front panel.
Threads: 147
City: Dallas, TX
Thanks Ron, I have refinished two early and late 16b,s using the extra dark walnut applying just enough toner to still see the grain. The diamond cloth or the chevron on my model? I have seen both cloth designs that seem to be factory on this model Philco.
Chevron, not diamond, cloth is correct for the late version 16B.
Threads: 14
City: Bakersfield, CA
Great radio! It seems this version may be the hardest to find... at least for me!
Threads: 20
City: Orland Park
State, Province, Country: Illiinois
That switch on the side doesn't seem original
Greg
Threads: 44
City: Menlo Park
State, Province, Country: CA
Greg,
It might be - some of the 16 series have an "Interstation Noise Suppressor" (old fashioned for squelch) and the switch allows this feature to be active or not. Typically, there will be a pot/rheostat to adjust the cut off point, accessible at the back of the chassis.
Cheers
Ed
Threads: 69
City: Kansas city, MO.
I believe it's a bass compensation switch.
Threads: 563
Ed Holland is correct.
Threads: 69
Wonder why they called it a bass compensation switch on the schematic? Just trying to learn.
In the case of this model (the later 4-band 16), KCMike is correct.
It is my belief that Philco decided they needed a switch to fill a hole in already-produced 16 cabinets when they introduced the 4-band 16 in late 1934 (after the 1935 season had begun), so they stuck an SPST toggle switch in the bass compensation section of the volume control circuit. I can't prove it because there is no supporting (or refuting) evidence that I know of, but it is a logical assumption.
The 4-band 16 does not have the QAVC (squelch or "Quiet Automatic Volume Control") that the 5-band 16 had...but it does add an RF amp, which is better than having QAVC.
Study a 4-band 16 schematic to learn more and see how the switch is placed in the circuit.
Threads: 42
City: Jeffersonville
State, Province, Country: PA
Hello all -
The side switch on my 16b turns the set on/off.
Regards,
Threads: 214
City: Seattle
State, Province, Country: WA
Beautiful set Paul!
Your set was likely modified later on in its life - perhaps to compensate for the power switch on the back of the volume control potentiometer no longer working (very common).
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
Model 27-84 BUZZ?Humm?
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM |
Is the tube in your radio actually 35Z3 or 35Y4, or something else?morzh — 10:55 PM |
Second Rich's opinion.
Run a separate antenna wire. Use a separate plug.
Rich
Where did you get this wire? Se...morzh — 10:51 PM |
