12-02-2017, 10:39 PM
What dial lamp to use in a 38 38t Chuck site doesn't have a number of a lamp for it should be 2.1 volt .12 amps.
38 38 dial lamp
12-03-2017, 12:34 AM
Use a 48 or 49 depending on the base. 222 penlite bulb is fine if you have a screw in socket. Current isn't critical as it's in parallel w/the A battery.
GL When my pals were reading comic books I was down in the basement in my dad's workshop. Perusing his Sam's Photofoacts Vol 1-50 admiring the old set and trying to figure out what all those squiggly meant. Circa 1966 Now I think I've got! Terry
12-03-2017, 11:29 PM
A 49 lamp is the half current of the original lamp would it be bright enough?
12-05-2017, 12:29 AM
Typically the lamps chosen for the least amount of current as it would deplete the A battery. If you think the 49 is too dim use a led, less current a plenty bright.
12-05-2017, 08:40 PM
Thanks I ordered a 49 not sure 2 volts would light a led.
12-06-2017, 11:10 AM
12-06-2017, 12:58 PM
I have not found any white led that are less than 3.2 volts I hope the #49 works ok if not might try #43 its 2.5 volts @ .35 amps.
12-08-2017, 11:25 PM
The #49 lamp was ok but it burned out after 2 or 3 hours so I tried a Christmas tree bulb out of a 100 string set it is brighter than the #49 was.
12-09-2017, 12:03 AM
We are not talking about the miniature Christmas lights are we? If so, it would not be a good idea. This type bulb has a shunt that shorts the bulb when it burns out.
Steve M R Radios C M Tubes
12-09-2017, 03:14 PM
That's what I used it won't short at 2 volts needs a higher voltage it gets when burns out it gets full line voltage across it of 120 volts.
« Next Oldest | Next Newest »
Users browsing this thread: 4 Guest(s) |
