Threads: 31
Hi Guys and Gals,
Putting the finishing touches on a model 70. In the process here's what I have so far and it's sort of baffling, at least to me.
When connecting an antenna wire to the proper post, there is little or no reception. When touching the wire on the grid cap of the 24 tube, 2nd one facing the front of the chassis, reception comes to life and fairly well. When I say touching, this is with my hand only. I notice that reception also comes to life if I touch the can that surrounds the coil underneat. Some abrupt jarring of the enclosure causes reception to be bit intermittent, but not enough to bring the set in or out of comission.
My thoughts, coil issue, either intermittent or something about to happen or perhaps alignment of the receiver. Any other thoughts? Ideas? Suggestions? I appreciate the assistance, and thank you all again. GB.
73 de,
Gary/N9VU
Threads: 55
City: Evanston, IL
Sounds like you may have an open antenna coil or open RF coil (just before the 1st. Det tube). Inspect the solder lugs on the coil forms for corroded or green spots where the fine wire connects to the lugs. Any greenish areas in the windings also indicates where corrosion has taken place. Coils can easily be re-wound. See this Service Tip on my site for guidance.
PHILCO SERVICE HINTS & TIPS - NUMBER 36
Rewinding Philco RF Coils
Hi Gary
Assuming you're working on an early 70 (without AVC), here's what I would check: - Antenna coil (2) and RF coil (6);
ALL wiring from tuning condenser to the various points under the chassis;
tightness of the screws on the sides of the tuning condenser;
the RF amp tube, Type 24.[/list:u]
I think it's probably a combination of bad antenna coil (2) and/or RF coil (6) and wiring/screw tightness issue on the tuning condenser.
The second Type 24 tube from the front is the mixer tube, so your problem has to be ahead of that. The wiring/screw tightness on the tuning condenser can cause lots of intermittents.
Hope this helps. Happy troubleshooting!
(edit) Well, Chuck and I answered at almost the same time, so now you have two votes pointing to those coils. Take a look at them right away. Good luck.
Threads: 31
mrphilco Wrote:Hi Gary
Assuming you're working on an early 70 (without AVC), here's what I would check:- Antenna coil (2) and RF coil (6);
Thanks Chuck and Ron for the advice. I've also noticed one of the 24's, the one in the very front may be bad just by it's looks, but this is a big maybe. The inner components are leaning to one side, not loose, but wondering if this is causing any malfunction in the receive as well. That's kind of a simple resolution. With the tube tester I have and a spare tube or two I'll see if this resolves anything.
Thanks again,
GB
73 de,
Gary/N9VU
Threads: 31
n9vu Wrote:mrphilco Wrote:Hi Gary
Thanks again,
GB
After taking the set down, I noticed the wire coming out of the coil to the secondary 24 has an open spot in it, just bare exposed. Could this be the problem of the grid cap wire to the coil?
73 de,
Gary/N9VU
As Bugs Bunny would say, "Mmmmmyyeahhh, could be..."
Threads: 31
mrphilco Wrote:As Bugs Bunny would say, "Mmmmmyyeahhh, could be..."
Hope the heck it is, LOL. By the way, what a difference some tubes made in this receiver. Picked up a half dozen 24's at ARCI today, replaced some trashy looking tubes in the 70, now getting reception with no antenna. Still an intermittent issue with the coil housing. I think once I straighten this out this is going to be one sweet old radio. Thanks again for your help.
73 de,
Gary/N9VU
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
Try BAMA for a schematic.
There are currently 4852 online users. [Complete List] » 2 Member(s) | 4850 Guest(s)
