RP-2 Tone Arm Pivot Questions
Working on a 41-RP2 with bad rubber in the tone arm pivot assembly -- as in no rubber left at all, it's completely disintegrated to powder. I'm trying to figure out the best way to replace the rubber, but I don't know for sure how it's supposed to fit together, or how thick the rubber itself should be. Does anyone have one of these with original rubber intact, who could give me a quick description of how it should go together?
Many thanks!
Hi
I've owned a couple of these in the past, but it has been a while, and I frankly do not recall any rubber in the pivot assembly. Sorry.
You might want to contact these fellows:
http://www.west-techservices.com/
They could probably help you out.
Good luck.
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4731 online users. [Complete List]
» 1 Member(s) | 4730 Guest(s)
