Philco model 18 capacitor value
Hello all, I'm plugging away on my model 18. I can't read the value of the capacitor which is internal to item #58, the tone control with a part number 30-4073. The condenser in question is item # 59, which they list as "condensers internal to 58". I can read the .05 uF value but not the other one, is it .003, .006, .008? Please let me know. I know either value will work here, since they are only filtering out high frequencies for the tone control function. Thanks!!
http://www.nostalgiaair.org/pagesbymodel...013149.pdf
In here I see #54 with two 0.05uF and one 3,000 uuF.
The speaker table error?
Philco 70 antenna lead
