Restoration info
Where can I find info on capacitor bakelite blocks? Also Philco resistor info (specifically wattage). The old philco repair bench link no longer works.
Thanks
All you have to do is use the Wayback Machine.
http://archive.org/web/web.php
In the box to the right of the Wayback Machine logo near the top of the page (the box already has http:// in it), just type in philcorepairbench.com and click the Browse History button.
You will be presented with a timeline. Any date from 2016 on back should work for you.
We have some bakelite block info here. Look:
http://www.philcoradio.com/phorum/showth...?tid=14964
and resistors:
http://www.philcoradio.com/phorum/showth...?tid=14966
See http://philcoradio.com/phorum/showthread.php?tid=14964 for how to view the info.
Is there an echo in here? Icon_confused
Looks like we replied at the same time. Icon_biggrin
This is a big help.
Don
Man,,,you guys are like CLOCK WORK,,,lololol
The speaker table error?
Philco 70 antenna lead
