Philco 7052 Tube Tester
Hi, fellow vintage test equipment enthusiasts. I'm new and glad to be here.  Icon_cool
I would appreciate any help in locating any info for a schematic and or calibration instructions for a Philco 7052 tube tester.
Would anyone know what tester is pretty close to it schematically speaking and if the Philco 9100 comes close?
Thanks
http://bama.edebris.com/manuals/philco/7050
The above link has the manual and schematic for the 7050
I don't know if it is close to the 7052 but it might help you.
Welcome to the Phorum!
Icon_wave
Thanks for the recommendation, but the 7050 is an emission tester and the 7052 is a mutual conductance tester.
Thanks, Cheers to you as well.  Icon_smile
https://www.radiomuseum.org/r/philco_dyn..._7052.html
Try this one it looks like it has the schematic.
You will have to follow their instructions to down load the pages.
I appreciate all your help, but unfortunately, they had uploaded the one for the 7050 which is an emissions tester only, instead of a mutual conductance tester which is what the 7052 is.
Thanks, for researching it.
