Philco 42-380 radio station tabs
Does anyone know where I can buy these radio station paper tabs for my Philco 42-380? They are dark brown in color and the letters are a beige color and fixed above the push buttons!!
Jimy
http://philcoradio.com/phorum/showthread.php?tid=4355
Free download. Icon_smile
OR - if you want to make your own:
http://philcoradio.com/phorum/showthread.php?tid=5148
Ron,
Thanks for the information! They will be like new!!
Jim
I just printed out a set as well. Thank you!
Hey Ron.....
That site is broken. Any place else the station tabs may be?
Good luck with the project and all of us here are expecting a full report when you're finished.
Have you Che ked the downloads section of the forum?
In case you have problems finding it, here's a direct link to the file here on the Phorum.
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Thanks Jeff. Icon_thumbup
I've also corrected the link in post #2 above.
