32-10048-1 Transformer information
Hello all, Can anyone give me the specs including color code for the 32-10048-1 power transformer? It will be greatly appreciated...as always
Ron K3PID
Welcome to the Phorum!
Icon_wave
I moved your thread into therestoration section.
What model radio is this in?
Don't know! It was in a box of misc parts. Looks to be in good shape but no info.
Ah...OK. there are some folks on here that have some old catalog info that might help. Hopefully someone will have some info for you.
My newest Philco parts catalog is from 1957, and it does not go any higher in 32-xxxx part numbers than 32-9689-1. So your transformer must be newer than 1957. Sorry I can't help.
The speaker table error?
Philco 70 antenna lead
