Grill Cloth Philco 70 Source
Where do we get grill cloth nowadays? I have not bought new cloth for Philco 70/90 radios in quite some time and I am having trouble finding it. where do you guys go?
Good morning Wilbur,
Sadly, there are really only two sources for grille cloth nowadays, and patterns are limited.
RadioDaze and Richmond Design.
http://www.richmonddesignsinc.com
http://www.radiodaze.com
I've purchased from both, and had good luck.
