Philco transformer identification
I'm looking for a transformer for my 39-3116 (39-116), and I ran across a nice Philco in my parts. It's part # is 32-8756. Would anyone be able to identify it from that #?
Hi Brad - I checked the 1949 parts catalog and didn't come up with a match. Hopefully somebody else knows. Icon_smile
I have a Philco 32-8248 power transformer I need help with. The wire colors are 2- black 2-red  2- white  2-yellow  2-blue  1- green   1- brown  I checked them got ohm results but not sure what Phico colors represent for power, filament,etc?
That was used in a Model 46-1226 and a few others.
you can see a full schematic on Nostalgiaair or audiophool sites
but here's the power transformer portion of the schematic.
[Image: https://www.dropbox.com/s/44n1x6iz6456em....jpg?raw=1]
Thank you.
91H Code 126 Restore
