Philco 90 Cathedral
Anyone know which Mohawk toners are needed to refinish a mid production 90 cathedral?
ThX
Medium Walnut.
If you're careful, you might add some Medium Dark Walnut in the grooves of the pillars on the left and right sides of the front panel.
Thanks Ron,
Did they apply the dark walnut to the inner grooves of the latice also?
If you mean the grille-work, then yes.
