Philco 41-266 Schematic
Is there a better schematic anywhere for this set other than what is in Vol 12 of Riders?
Joe
Hi Joe
No such thing. Do you mean 41-265?
Sorry. The model number is 41-226.
Try this one. David
Or if you prefer here's the Philco service info:
http://www.audiophool.com/Philco.html
Just click on the appropriate model #
Thank you, Terry.
Joe
The speaker table error?
Philco 70 antenna lead
