Help identifying a philco model
http://www.nostalgiaair.org/pagesbymodel...014123.pdf
compare tubes in schematic to tubes in top view of chassis
elfiself
Ah! Now I see what you are saying.
The tube layout in the Rider's print has an error. Here is a corrected layout:
Thanks Ron
Ron I'm wondering if it's possable to determine for sure this chassis is aPT-12 and not a 42-PT10 since the schematics are identical. And would I be safe using the parts list from the Riders 42-PT10 schematic for the PT-12 since as the Rider PT-12 sch. dosen't include a parts list.
elfiself
There are currently 11074 online users. [Complete List]
» 2 Member(s) | 11072 Guest(s)
