03-05-2018, 04:25 PM
Does anyone know if a power transformer for a model 87 will work in a model 86? The schematics look almost the same.
Dave Thomas
Coatesville, PA
Philco 86 Pwr Trans
*********** Dave Thomas Coatesville, PA
03-05-2018, 05:09 PM
Well.....philament voltage for 71A is 5V at 0.25A and for 45 is 2.5V at 1.5A, so the "C" winding is different. Otherwise it would work.....
03-06-2018, 10:30 AM
Thanks for catching this morzh. I didn't dig deep enough and wrongly assumed the filament voltages would be the same.
03-06-2018, 12:32 PM
Dave,
What sucks that for the most part they are the same ![]() Except the Pus-Pull section. Then again, maybe you could fit the 45s into it instead of 71A ![]() Could require some mods.... People who do not drink, do not smoke, do not eat red meat will one day feel really stupid lying there and dying from nothing.
03-07-2018, 12:17 AM
The issue with the #45s is that they require more B+ voltage, and more bias I believe, I think you can use the same output transformer. It may be pretty close anyhow, the #45s run ar 2.5 volts but draw 1.5 amps, the 71As run at 5 volts but draw .25 amps, so the same winding with 1/6 the current draw. Are you sure that the original transformer has failed? Does it run hot, or smokes, or is open circuit?
Regards Arran
03-17-2018, 10:20 AM
It's definitely shot. It looks like someone attempted to "repair" it before me and literally toasted the PT. The good news is that I found a stripped down 86 chassis on eBay that still had the PT on it. I took a chance and bought it for $30 and after I rewired the primary and CT leads it worked like a charm. Reinstalling it will take a while but it looks like I'm back on business.
03-17-2018, 11:18 AM
Sounds Great!
When my pals were reading comic books I was down in the basement in my dad's workshop. Perusing his Sam's Photofoacts Vol 1-50 admiring the old set and trying to figure out what all those squiggly meant. Circa 1966 Now I think I've got! Terry
« Next Oldest | Next Newest »
Users browsing this thread: 4 Guest(s) |
