52B grill cloth
I'm in the process of restoring a 52B. I'm looking for suggestions on replacement grillcloth.
http://www.radiodaze.com/grille-cloth-02-item-grc02/
A light dusting with walnut toner will make it more original in appearance.
Thanks, and thanks for the toner idea.
