philco 45 cabinet
I was wondering what finish to put on my philco 45 table radio , what mohawk stainfor the cabinet in most corners and what for the accent strips , that flowdown to the bottom of then radio on front ? there is nothing light colored left of the lighter colored accent strips i usually see on this model. it is dark walnut or has been stripped to that .
The cabinet should be sprayed with Mohawk Extra Dark Walnut overall. The accent panels in front are Medium Walnut.
The grooves in front can be filled with tan nail polish - nail polish is lacquer-based, so it should not interact with the coats of clear lacquer when you apply these.
This picture shows what a 45C (and 28C) should look like:
http://www.philcoradio.com/gallery/1935a.htm#u
There are currently 8371 online users. [Complete List]
» 2 Member(s) | 8369 Guest(s)
