What type is this?
Friend fell on hard times.  Trying to find out how much he should ask for this cabinet.
https://ibb.co/diVVX7
Hi and welcome!
A little too new for me but best guess is that it's from the mid '70s and isn't commanding much of any price. Most are happy to be rid of them.
Sorry
Not too popular, I'm guessing $25.00.
Dunno may be getting rare, 15-20 years ago the curbs were lined with those on pickup days...
Tom
Sorry to join the chorus, but in the unlikely event this sells, $25 will be the limit.
There are currently 10920 online users. [Complete List]
» 3 Member(s) | 10917 Guest(s)
