04-12-2018, 08:45 PM
No. Those are not brass grommets.
Where to find eyelets and tool(s)?
04-15-2018, 01:04 AM
Crist
04-15-2018, 08:46 AM
Crist
That was beautiful work you did on your 60 chassis. Absolutely beautiful. However... I do not have the skillset needed to make my own flaring tools for this project, let alone modifying eyelets with tubing. I'll just use pop rivets and drill a hole for the wire. Thanks everyone. -- Ron Ramirez Ferdinand IN
04-15-2018, 03:19 PM
Let's keep looking. The ones we want and the tool are out there - somewhere.
04-17-2018, 10:42 AM
A Phorum member called me and gave me a very good idea.
![]() -- Ron Ramirez Ferdinand IN
04-20-2018, 12:05 PM
this is a very good topic.
i used regular rivits once and the shoulder of the rivit was touching the case of a filter cap due to its size. i was wondering the same about if there is a resource for "smaller" shoulder rivits available and yes eyelets are going to be easier to find than the smal rivits i would think. watching this thread! thanks!
04-20-2018, 03:15 PM
Hello Ron, I used these for attaching tube sockets.
https://www.amazon.com/gp/product/B00BL6...UTF8&psc=1 I used a 3/16 eyelet setter and anvil that I bought off of ebay. I hope this helps, Kelly "He has all the virtues I dislike and none of the vices I admire." — Winston Churchill
04-20-2018, 04:23 PM
Link doesn't work.
04-20-2018, 05:20 PM
Try this. I think I omitted some of the address. "He has all the virtues I dislike and none of the vices I admire." — Winston Churchill
04-20-2018, 05:28 PM
theres gotta be a hand held tool for this,,, i cant imagine the original builders would be using two separate tools. i may dig into this, i saw a similar rivit on my 88tbird, a very small type of rivit and it comes very close to the size on tube sockets.
04-20-2018, 05:31 PM
one thing i forgot to bring up. the same application would be used on shoes which have various size eyelets that also in my opinion act as a rivit. the problem with this is that the tool itself needs to be working both sides of the metal. a rivit gun only works one side.
04-21-2018, 12:29 PM
(04-20-2018, 05:20 PM)Greenhorn Wrote: https://www.amazon.com/gp/product/B00BL6...UTF8&psc=1 These are too light-duty for the application on a radio chassis. I have the tool for these.
04-24-2018, 10:11 PM
So...I told you a week ago that a Phine Phellow Phorum member had given me a call and made what I thought was a very good suggestion, but I did not elaborate.
Having finally found the time to get what I needed from the hardware store, I tried his idea out tonight and it worked! Here's the details. Ed suggested that I install the combination of tube socket and tube shield base with two 5/32" or 3/16" aluminum pop rivets, and then take a nail and knock the head out of the rivet through which the wire needed to pass. It wasn't easy geting the head out of the rivet, but I was able to do so and, as far as I could tell, nothing was damaged in the process. The new cloth-covered wire easily fits through the hole in the center of the rivet. Problem solved. Thanks Ed. ![]() One of these days, I may still try my hand at setting brass eyelets. That is, once I get my mitts on the proper setting tools. -- Ron Ramirez Ferdinand IN
04-25-2018, 04:19 PM
Note - I just googled, and copper "pop" rivets are available, if that is a more appropriate material than aluminium.
For audiophiles not wanting Pop rivets, Classical and Jazz rivets can be obtained (at inflated prices) ![]() P.S. I'm not the same Ed to whom Ron referred to in his last post. I don't hold with furniture that talks.
04-25-2018, 05:12 PM
The ones we really need are brass and nickel plated brass. They end up looking the same on both ends when installed properly.
« Next Oldest | Next Newest »
Users browsing this thread: 2 Guest(s) |
