Threads: 44
City: Menlo Park
State, Province, Country: CA
Hi folks - chimeing in as I heard my name
The picture shows a hole pattern exactly the same as I tried to reproduce. This I did from a picture on the net, scaling to get hole size and spacing.
I estimated holes are 1-3/8, spaced at 2". Top row is 10 holes, next down is 8. The whole pattern, top to bottom goes:
10, 8, 10, 8, 10, then again 10, 8, 10, 8 10.
Hope that is helpful,
Ed
(04-14-2018, 11:00 AM)gregb Wrote: I am recovering from knee replacement surgery...
Ouch, sorry to hear that. Best wishes for a speedy recovery!
Threads: 24
City: Edmonton AB CA
Thanks Ron, its coming along just fine and I am just starting to walk unassisted. Its been a long slow recovery and not a whole lot of fun but everyone I have talked to that has had this done say its worth all the trouble, fingers crossed!
Gregb
(This post was last modified: 04-14-2018, 10:47 PM by gregb.)
Threads: 562
Greg
Feel better, hopefully it's worth all the suffering through it.
Threads: 24
Thanks Mike, I am looking forward to the end game.
Gregb
Threads: 147
City: Dallas, TX
Threads: 147
City: Dallas, TX
Threads: 147
City: Dallas, TX
> I'm thinking the radio may have more Bass if I don't drill the holes in the back cover, what do you thing Ron?
It will have plenty of bass with the proper back. It's up to you if you want to install a plain back with no holes, though.
> radio daze has this dial its for a miodel 18lzx I'm wondering it sure looks like what I need , will this work is what I want to know.
Will it work? Yes. Will it be authentic? No, simply because the 18RX has a different coverage on its band 2 than does the 14LZX (1.5 to 4.2 mc in the 18 versus 1.4 to 3.3 mc in the 14LZX).
Threads: 24
Hey Fred, I would just give the guys at Radio Daze a call, they will make anything you want and for the same price you would pay for the one above. I have had them done with no problems.
Gregb
Threads: 147
City: Dallas, TX
Threads: 147
City: Dallas, TX
Threads: 112
City: Medford OR (OR what?)
That looks good Fred.
Threads: 11
City: Bellmawr, NJ
ALL ,,I ,,,CAN say is ------SHOW ROOM Material
Threads: 72
City: Linn Creek, MO
Fred, your work is amazing!
M R Radios C M Tubes
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM |
Philco 91 Tuning Condenser
I just found a set screw. Was able to turn dial just enough to see it and loosen it. I have it off now.dconant — 06:14 PM |
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM |
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM |
Transistors are easy.
Or touch your fin...morzh — 04:25 PM |
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
There are currently 10108 online users. [Complete List] » 3 Member(s) | 10105 Guest(s)
