shield question
Does anyone know if the three gang RF tube shield from a model 20 will fit a 91?
Thanks!
If it glows in the dark and heats up the house its MY kind of radio!  Icon_crazy
No, it will not.
Have you tried Chuck Paci? He makes reproduction Philco tube shields that cannot be distinguished from the originals.
cpaci1 at verizon dot net
And the labels.
Thanks Ron. I sent him an email
The speaker table error?
Philco 70 antenna lead
There are currently 6055 online users. [Complete List]
» 1 Member(s) | 6054 Guest(s)
